DougDR
Dual ext
Hi ..... yes I new
I have a dual ext 3D printer and I want to be able to print my part in ABS and the raft and supports in PLA. I am using Simplify3D
HOW? please help
andrewk72
Re: Dual ext
Just select "Both Extruders" for the auto-configure extruders option and then go to the Temperature tab and edit the temperatures for the left and right extruders as needed.
You can then select what extruder is used for the part, raft, support, etc. It's all in the process settings.
DougDR
Re: Dual ext
andrewk72 wrote:Just select "Both Extruders" for the auto-configure extruders option and then go to the Temperature tab and edit the temperatures for the left and right extruders as needed.
Thank you very much. I still have a lot to learn
Is there a document that enplanes all the setting ?
Re: Dual ext
Have a look at this thread....if you haven't already. It explains every setting in the print profile...some in great detail.
viewtopic.php?f=8&t=2367
And it's easy to find....at the top of the General Discussions section of the forum!
andrewk72
Re: Dual ext
I learned a lot just from watching their youtube series, so I would suggest starting there
https://www.youtube.com/c/simplify3d
Re: Dual ext
They also have many articles on their website that explain some of these topics (like multi-model printing and dual-extrusion)
https://www.simplify3d.com/support/tutorials/
