Brutal-Force
Davinci Duo 2.0 - Printer Rebooting on build
Ok, something is weird.
My printer keeps rebooting after sending file over. It shows receiving job, then the lights go out and it reboots.
I was using 3.1 so I downgraded back to 3.0.2. Not rebooting now, but I am getting a weird glitch. It stops printing after 2 or 3 layers (even on multiple items).
It shows cartridge error.
I am using WCTEK Zerocartjr
Please help.
Re: Davinci Duo 2.0 - Printer Rebooting on build
Can you post your factory file? Perhaps it has to do with the settings you are using
Brutal-Force
I will upgrade to 3.1 again after I finish a print. Then I will see if the problem persists.
By file, you mean the Gcode or just the file? I know the file works on 3.0.2 because I have printed it already. As for what I printed, I will attach the spiral pawn. Any attempt at more than 1 was causing a reboot.
Thanks
Pawn.stl
(935.04 KiB) Downloaded 224 times
No, I mean the factory file. Setup everything, and right before you click "Begin Printing over USB", go to File > Save Factory File.
If you haven't heard of these files before, I would read this: https://www.simplify3d.com/support/tuto ... ile-types/
Brutal-Force
Ok, as soon as I upgrade I will send it.
Brutal-Force
So far so good. I wonder if there was some XYZ shenanigans going on. I will update the thread should I start to have problems again.
Brutal-Force
Ok, it failed again with multiple prints
Example.factory
(24.95 KiB) Downloaded 216 times
Good, I'll see if I can try this. You're using the da Vinci 2.0 duo, but what exact firmware version does your printer have?
Brutal-Force
Just reporting back. This has been fixed with latest update. S3D sent me a FFF profile which did not have this rebooting problem.
