Ive been trying a few ways to print an aerofoil section for a wing. Two main methods:-
1. design the wing as solid and let S3d hollow it out with sparse infill
2. design it as a 'shell' in CAD and print it 'as is'
The problem with the second option is that S3d does not print the outer skin in one movement but jumps about between the bracing and therefore the surface is not great.
Method 1 produces a beautiful outside skin but any internal structure is not well supported. Notice I have put small slots and holes near the spar tube in an attempt to connect it to the outer skin. Also the infill adds another internal wall layer for about 70% of the perimeter, adding weight.
It would be great to be able to add localized internal support, similar how the external is done. I have tried various infills and fill % but the rectilinear seems to produce the best result, even if some of the infill lines are not well joined. Guess needs a bit of tweaking.
Any ideas welcome.
