PS: The files are in separate .tar.gz archives, to stay within the forum limit of 3 files of 3MB max. You could make it easier to report bugs in the future if these limits could be relaxed.
I see. Well, I'm happy to've been able to provide a useful test-case.dkightley wrote:Try changing the layer height to 0.4004 mm and re-slice.
There is some sort of anomaly in the mesh that S3D is not able to interpret correctly when it is encountered at a multiple of 0.4 mm. Changing the thickness to 0.4004 mm misses the exact spot that is causing the issue.
This is a known issue that I used to happen fairly often. Some development changes in one of the more recent mini-releases seemed to reduce the frequency of this issue...but you must have a model that is still causing the problem.
I should probably have realized this. Why else would the factory file be so large?dkightley wrote:btw..you only needed to attach the factory file. It contains the stl file.....and the gcode file could be created simply by slicing.
