carlbeck
Not printing details of stl file
As Shown when imported
I have 2 stl files that will not print as shown in the stl import.
Standard Prusa Setup
Details not Printed
Details not Printed
endcap Print Preview.jpg (27.07 KiB) Viewed 5345 times
Jeff_Birt
Re: Not printing details of stl file
Typically attaching the factory file will get you more help. There is just no way to see the problem from pictures.
carlbeck
endcap.factory
(7.05 KiB) Downloaded 296 times
Here is the Factory File.
Jeff_Birt
Go to the advanced tab and deselect 'merge all outlines into single model'.
carlbeck
Thank you very much. I would have never thought of that. I assumed when you installed it, those boxes would be correct for default printing. But: Then again I know what it means to ass u me. :)
Where can I find the description of what each of those check boxes really do in Simplify3D?
Jeff_Birt
dkightley wrote:viewtopic.php?f=9&t=7497
I'm not sure what the post you linked to had to do with this thread?
Read the thread! It contains a list of other threads that contain explanations for every setting on every tab of the profile.
The answer to the question "Where can I find the description of what each of those check boxes really do in Simplify3D?" is in one of the threads. You just have to look for it.
Jeff_Birt
There is no list in that thread. Maybe you pasted the wrong link :)
Jeff_Birt
I think maybe you meant this thread: viewtopic.php?f=8&t=2367
