I've been printing everything in PETG these last few months and successfully, once I fully appreciated the importance of keeping my filament dry. Last night I loaded my biggest file ever, using 7.5" of my MakerGear table in the "X" dimension. After many layers (not sure of the count), I'm guessing ~8mm high, the entire print shifted off the platen almost 1.25" in X. After attempting to print another 5-6mm in height, the entire model shifted almost 2" in Y. It was an 11 hour print job, running unattended over night. This morning I found this mess, aborted.....
I've read through the related Posts that I could find, checked for loose pulleys, belt tension seems OK or very close. The printer is in my shop outside, humidity controlled, 65 - 70 degrees at this time of year. What else can be wrong?
Thanks,
Doug
