coopdway
Print shifting - Both X and Y
I've been printing everything in PETG these last few months and successfully, once I fully appreciated the importance of keeping my filament dry. Last night I loaded my biggest file ever, using 7.5" of my MakerGear table in the "X" dimension. After many layers (not sure of the count), I'm guessing ~8mm high, the entire print shifted off the platen almost 1.25" in X. After attempting to print another 5-6mm in height, the entire model shifted almost 2" in Y. It was an 11 hour print job, running unattended over night. This morning I found this mess, aborted.....
I've read through the related Posts that I could find, checked for loose pulleys, belt tension seems OK or very close. The printer is in my shop outside, humidity controlled, 65 - 70 degrees at this time of year. What else can be wrong?
Thanks,
Doug
coopdway
Re: Print shifting - Both X and Y
Read it long ago before I was having trouble and forgot to go back and look, thanks for the reminder.
witmore1
If the above troubleshooting page fix it, it could be that you are exceeding your build plate size,
I have added a glass build plate to my FFCP and using 8x10 glass I can print beyond the 6x9 original build plate, but not by a whole lot,
when I have sent files to it that hit a an extreme it causes a shift after that point.
your part fills the bed pretty close to the edges but the skirt looks like it might be really close to one edge I can't tell exactly though.
coopdway
Read the Troubleshooting Tips, made some changes and printed a model that I'm very satisfied with. I'll post a GOOD photo this evening.
1) Rebooted everything
2) Checked lock screws, all seemed tight. Did tighten up belt tension slightly.
3) Slowed printing speed to 75%
4) Print ran over 18 hours+ which meant overnight. The shop has a ceiling fan that normally runs but overnight, lights out, no fan. I plugged in a table-top fan nearby and ran that during the entire print run.
Witmore1, part is 7.5" in dia and you are correct, the Skirt did run off the table. I worried about that until 25 layers were down and all seemed OK with the model itself.
Appreciate the help, my customer even more so!
coopdway
Here's the finished print run.
