lensfort
[FIXED] Prime Pillar not changing on last layer
On the last layer of my dual colour prints, the very last layer, when it needs to change colour, it moves to the prime pillar and primes the CURRENT colour, then moves to the job to finish the colour change. And in doing so messes up the last layer.
Load up attached file in S3D 4 to see and screenshot
Screenshot
Screenshot
RynoHire Keyring Dual x4 - face down.gcode
Generated GCODE
(957.04 KiB) Downloaded 190 times
Swesen
Re: Prime Pillar not changing on last layer
I can confirm this I am also having the same problem:
yves_hsu
I also encounter the same problem. Will it be fixed in next release?
This issue has now been fixed in Version 4.0.1. The prime pillar sequence for the last layer of the print has now been corrected for the situation mentioned above.
Thank you for reporting the issue!
