blackbird2016
[FIXED] V 4.0.1 Start point to specific location works not anymore
JasonCS wrote: Our team will definitely be investigating any potential issues that are found with the new version, so please go ahead and make a separate thread in the correct forum for any of these items that need to be addressed. That will help keep things much more organized as our team investigates the potential issues.
As always, it is also a big help if you can include as much data as possible including the factory file, system information, etc. Many times, it is not possible to reproduce the issue without these items.
Sorry for posting in the wrong thread. :oops:
Here is what I intially wrote.
Start point to specific location does not work anymore.
Seems, it always is the fastest print settings.
Just did a rollback to 4.0.0 and it works again.
Just added 3 factory files and a screenshot of each one sliced.
One with 4.0.0 which works as intended.
Two of 4.0.1 where it does not work.
I am with WIN10 64bit Core i5 6500 8Gb fully updated
Thanks for looking into this.
start points.zip
(607.84 KiB) Downloaded 458 times
NitroXpress
Re: V 4.0.1 Start point to specific location works not anymo
+1
4.0.0 no Problem...
NitroXpress
Nobody else noticed this problem with V4.0.1 ?
NitroXpress wrote:Nobody else noticed this problem with V4.0.1 ?
I have no behavior with it,
have a look to the attached pic.
Its a small cover like a frame I have printed and for testing I have switched the starting point to X=0 Y=0
As you can see, the real starting points are indead near X=0 and Y=0 (edge on lefthand side), the small tongue has no wall around, therefor the printhead jumps from one side to the other side, thats not a real starting point.
Regards
GER
gearsawe
In the layers tab, uncheck the setting Print Island Sequentially without optimization.
checking this should grey out option to choose start point to closest point.
Sorry, but that has no influences on my S3D-4.01 installation; all 3 option are available and I can choose them.
H.
gearsawe
using 4.0.1 here with
Print Island Sequentially without optimization UNCHECKED
target at 0,0 front left
target at 100,100 back right
with it checked it ignores the start point point.
NitroXpress
OK guys, many thanks for the hint !
Indeed it works with "print islands sequentially" unchecked.
No problem, when printing only one part.
But if you print more than one part, a new thread on a new layer is printed on top of a just printed thread.
No time to cool down.
I'm wondering about this new behavior in V4.0.1...
Frank
NitroXpress
Start Point should be upper left corner.
With V4.0.1 no start point control possible.
Works as expected in V4.0.0 !
Both with "print islands sequentially" checked...
blackbird2016
gearsawe wrote:using 4.0.1 here with
Thats correct.
Unfortunatelly for most of my prints I want that to be unchecked.
Would be happy this would be fixed...
