-Would be nice to edit multiple FFF processes at the same time. Ability to highlight selected FFF processes, and edit. Very time consuming to edit each one individually. (If different process have different settings, just leave the fields blank to let the user know, this is how other software handles this)
-When I have 10 parts on the table, and add a new process for one part, I would like the model to already be set to the current model selected. (or multiple selected) Very time consuming to go through the menus to select each model every time.
-When doing sequential printing, I would like another option to print in order of the FFF process list. (For example, currently if I have 9 parts on the table, and each part in split into 2 process, .2mm height first, then .1mm last. I want each part to fully print before moving to the next part. Currently the slicer doesn't follow the process list.) I like to fully print a part before the next to prevent cool down of the part, less blobs and zits, no visible start and stops.
-I would like the options presented when "prepare to print" is pressed (sequential, which parts, height clearance) to be persistent. Having to enter all this in every time I want to make a small change is time consuming. Maybe save to the factory file?
Other - I would also like the toolbar location to be persistent. I like it on top, but never saves.
Thanks for the great software!
