I believe the OP wanted to enable sequential printingtri-lite wrote:Click on any of your models to open the fff dialog box. In the bottom left, click on "Select Models". A popup window will appear listing all your models, and then you can click on "Select All" in order to have your fff settings applied to ALL your models. Is that what you were trying to achieve?
Thanks for the tip. On my computer ctrl + V does the trick (instead of ctrl + P). Very helpful.severan500 wrote:I do not know whether it is still relevant, but the copying process is very easy, just mark the process and press ctrl + C and ctrl + P.
mr0ng wrote:Thanks for the tip. On my computer ctrl + V does the trick (instead of ctrl + P). Very helpful.severan500 wrote:I do not know whether it is still relevant, but the copying process is very easy, just mark the process and press ctrl + C and ctrl + P.
