racedisplay
CreatBot F430 Not in 4.1
Can't find CreatBot F430 in the printer selection list of version 4.1, bug?
dhogendoorn
Re: CreatBot F430 Not in 4.1
Yes I have the same issue, I was happy when I found the F430 had been added but I cannot find it through configuration assistant
dhogendoorn
Yes I noticed this as well. I have manually created my own but a proper one would be nice since the website says it has been added
racedisplay
What machine did you use as template for the custom F430 machine setting?
regards
dhogendoorn
Originally I just selected "other" and typed in 400x300x300 in the machine settings and transferred all the other data manually from their creatware that came with the printer.
This worked until I started playing around with dual extrusion because the dual extrusion wizard wouldn't work with a custom profile. I am currently using the Creatbot DX dual extrusion profile and just changing the build plate size. I haven't printed anything since changing to this but I'll keep this updated as I figure things out
Please contact our support team. They will be able to help you with the profile and any special instructions required for working with the printer.
dhogendoorn
The DX dual extrusion profile doesn't seem to be working correctly. I can't experiment with it yet as the printer is currently in use but I will most likely tomorrow
BOSVISION
Hello All
Have the same question about the F430.
Mailed already support since last weekend and no reply yet.
You have to pay to discover that that your unable to select the F430.
phamd4
Hello,
I just downloaded the newest simplify3d and using it with my f430 also. However I cannot find the setup profile. The cretware comes with the printer cannot run on my computer.
Can someone please help me share their profile please ?
I contacted the help line for 2 days now but I haven’t heard anything from them yet
Thank you so much
S3D-Chris
phamd4 wrote: Mon Jun 17, 2019 3:00 pm Hello,
Thank you so much
Please contact us at [email protected] and we will send you a profile to try!
