racedisplay
CreatBot F430 Not in 4.1
Wed Nov 28, 2018 9:50 am
Can't find CreatBot F430 in the printer selection list of version 4.1, bug?
dhogendoorn
Re: CreatBot F430 Not in 4.1
Thu Dec 13, 2018 10:26 am
Yes I have the same issue, I was happy when I found the F430 had been added but I cannot find it through configuration assistant
dhogendoorn
Thu Dec 13, 2018 10:54 am
Yes I noticed this as well. I have manually created my own but a proper one would be nice since the website says it has been added
racedisplay
Sat Dec 15, 2018 3:41 am
What machine did you use as template for the custom F430 machine setting?
regards
dhogendoorn
Mon Dec 17, 2018 10:23 am
Originally I just selected "other" and typed in 400x300x300 in the machine settings and transferred all the other data manually from their creatware that came with the printer.
This worked until I started playing around with dual extrusion because the dual extrusion wizard wouldn't work with a custom profile. I am currently using the Creatbot DX dual extrusion profile and just changing the build plate size. I haven't printed anything since changing to this but I'll keep this updated as I figure things out
Tue Dec 18, 2018 3:52 pm
Please contact our support team. They will be able to help you with the profile and any special instructions required for working with the printer.
dhogendoorn
Wed Dec 19, 2018 2:26 pm
The DX dual extrusion profile doesn't seem to be working correctly. I can't experiment with it yet as the printer is currently in use but I will most likely tomorrow
BOSVISION
Thu Dec 20, 2018 4:42 am
Hello All
Have the same question about the F430.
Mailed already support since last weekend and no reply yet.
You have to pay to discover that that your unable to select the F430.
