svg
Re: 4.0 Problem,model disappears when prep to print
Thu May 09, 2019 10:02 am
Hi
I suddenly also ran into this with v4.1.2. I add the model, have a process, have the model also selected in the process, and when I slice, I get build time 0 hours and there is nothing to see. The slice process is also instantaneous, so it actually is skipping the model.
When I add supports, I can see the paths for the support, but the model itself is not sliced.
It has worked before, but suddenly stopped.
Please help, because also other models cannot be sliced anymore.
s
svg
Mon May 20, 2019 5:03 am
It seems like this was a license issue. I made a refresh on the account and then it worked again. A better error message would be nice because else it all worked fine...
Fais
Mon May 27, 2019 5:56 pm
I'm having the same issue. Attached is the factory file.
Straight 2.factory
(10.69 KiB) Downloaded 143 times
