Re: BUG: 4.1 prints supports when told not to print them
Mon May 13, 2019 7:35 pm
...…..I removed the automatic supports from fours holes. They don't show up in Preview mode,
Well they do for me......
TheBum
Re: 4.1 prints supports when told not to print them
Tue May 14, 2019 7:04 pm
Can you confirm that there aren't any supports on that object in the custom supports tool panel? I know the other object has supports in one area.
To work around the issue, I ended up splitting the print into two processes, with support enabled for only that one object. I've used this workaround several times when I've encountered this situation, but it doesn't excuse the developers from fixing it.
Tue May 14, 2019 7:25 pm
You didn't add any.....and neither did I.
