TopHATTwaffle
Change in "Perform retraction during wipe" behavior?
While troubleshooting a retraction issue I looked at the GCODE generated by 4.1.2. I have wipe and perform retraction during wipe movement on. It looks like in 4.1.2 S3D does a single retract move and then the wipe travels. Where in older versions, like 4.0.1 there is a retraction during the entire wipe movement. Is this intentional? With the same settings between these 2 versions I have a better time with stringing/ooze in 4.0.1 vs 4.1.2
This is a snipped from the same file sliced with the same profiles between the 2 versions.
4.0.1:
G1 X153.725 Y135.962 E-0.7881 F4800
G1 X153.846 Y134.894 E-0.8066
G1 X153.938 Y133.796 E-0.8263
G1 X153.986 Y133.025 E-0.5789
4.1.2:
G1 X153.648 Y136.513 E-3.0000 F600
G1 X153.725 Y135.967 F600
G1 X153.845 Y134.899
G1 X153.938 Y133.801
G1 X153.985 Y133.030
S3D-Alex
Re: Change in "Perform retraction during wipe" behavior?
Could you please post the Factory File that created these two gcode files so we can look into this further?
Hergonoway
same here, got blob before every wipe depending of the lenght of the previous move....
Example from line 726
G1 X-9.760 Y9.760 E0.7791
G1 X-9.760 Y8.814 E-1.0000 F2554
G1 X-9.760 Y6.760 F2554
; feature infill
please find factory file in attachment
meh.factory
(3.54 KiB) Downloaded 197 times
