Here is a picture from my last print, during the first layer:
It's far from perfect... What settings should I change to get a better first layer?
Factory file is attached.
Thanks,
Patrick
READ: Bilinear Leveling Grid:
READ: 0 1 2
READ: 0 -0.580 -0.625 -0.420
READ: 1 -0.665 -0.727 -0.614
READ: 2 -0.602 -0.710 -0.602
You should ensure that your G29 command is after any G28 command, as the latter resets the levelling data.Seiphi wrote: Good morning, sir,
I think I have a problem similar to PatrickJ's.
I have a BLtouch and I added the G29 in the starting Gcode.
However, it seems that simplify3D does not take into account the auto-leveling because as you can see on the picture above I am more squashed on the right than on the left.
My bed has a hollow in the middle of it, hence the fact that I added the sensor.
Do you have any idea what the problem is?
The photo has been tested with a 0.1mm layer print with default settings.
Regards.
