Just purchased the program and cant figure out how to change a few things.
Im Using a Makerbot rep 2x, current sailfish firmware with the bottleworks Almn build arms and glass build plate. All prints are in ABS
Is there a way to change the amount of purge material that is extruded at the start of a print.
When the extruder begins to start the print, Im getting what looks like dots and then a solid shell line...Id say it takes about 10-15mm to actually get going. At first I thought it may have been an extruder issue so I tore it apart and gave everything a good cleaning....same issue happened again. Ran the part from makerware and problem was gone. What setting would resolve this issue?
Thank You
Brian
