S3D-Jason wrote: ↑Thu Dec 15, 2022 12:30 pm
A3D-L wrote: ↑Thu Dec 15, 2022 7:46 am
Btw where are the firmware and communication settings?
I believe many of the firmware and communication settings are now auto-detected behind the scenes. You shouldn't need to manually configure those anymore. If the printer connections using the device setup wizard, then the software will remember those settings for the future.
I know what you mean, but I have to change different settings to make our 3d printer work.
We are a 3D printer manufacturer and for some things we had to define for example the tool change from T0/T1 to M6 T0/T1 or the percentage of the cooling fan is in a range from 0-100 not from 0-255. I can't change the buffer size anymore too to make the printer work in a smoother way without any stops. With the M105 there is an extra Command M27 which we don't need.
We need a full machine control panel as well because we can't drop the gcode on a sdcard - we are just working with a direct communication because we don't use an extra screen to change the flow rate and so on.
So right now our customers won't be able to use S3D anymore. That's pretty irritating.
I am a process developement engineer in a company which produces pellet 3d printers for industrial use and I am scared that we can't use S3D anymore for our products that we are manufacturing and selling.
