crashmaster
Holograms
Anybody know why my model has these Holograms inside and outside of features?
crashmaster
Re: Holograms
Other areas of the print…
SOME BASIC SETTINGS:
2.5mm Retraction lift
0.12mm layer height
202 degrees Extruder temp
70 degrees bed temp
50 speed
POLYMAX PLA 1.75mm
Re: Holograms
That looks like ringing. There's an article about it here:
https://www.simplify3d.com/resources/pr ... d-ringing/
Thomasengelmann
Re: Holograms
Your print has a lot of issiues, but the problem you ate talking about is ghosting, your printer is vibrating. You can reduce the speed or acceleration or you can make the printer more sturdy
ptegler
Re: Holograms
yep..not slicer coding issue...that's a hardware settings issue. Acceleration is too high, belts are too loose, or trying to print too fast. You have to find the balance for your machines capabilities
ptegler
