Schmittk
Settings for Vellemann Vertex K8400
I'm looking for the best settings for my Vellemann Vertex K8400 3D printer.
Anybody using this with S3D?
taps78
Re: Settings for Vellemann Vertex K8400
I'm trying to use it also for my k8400, the support structure is great, but the the print is like polystirole foam :( i think the flowrate ist to low. would be great if there is a import filter for the cura settings ;)
pinthenet
I've just installed S3D and I'd be grateful for some tips (the Vertex is also my first 3D printer). I read on the Vertex forum about deleting the heated bed, but some other settings, namely XYZ parameters and 'Flip Build Table Axis' set for Y-axis don't look right compared to the Vertex Repetier-Host settings. Should I set to the same as Repetier or doesn't it matter - I did choose the Vertex 8400 as machine. I haven't got round to starting a print yet
ejeklint
Nice with a Vertex thread! I've just started printing and there is obviously need for a lot of tuning to get the optimal print. With the default settings for K8400 I get too thick walls so part within parts that should be moving gets stuck in each other. I have tested with lowering the flow and that helps but then I get an almost see-through top layer. Look forward to share experience here.
One immediate question: Velleman says nozzle size is 0.35mm but Simplify3D has that setting as 0.5mm. Is this correct?
Does the Vertex use the same extruder at the K8400?
[email protected]
Hello :)
I started using the vertex a few days ago.
My settings inn S3D Is like this.
Nozzle Diamet: 0,35
Extrusion multiplier 0,72
first layer heigt: 200%
Temp: 192
Trying out different speeds now.
I`m a noob, so every input is great.
Ocd. Norway.
