dougirwin212
Simplify 3D won't start after installation
I have installed Simplify 3D on a Window's 7 computer 64 bit system. Installation works fine after logging in with user name and password the software does not start. From that point on each time I try to start it I get the error, "Simpify 3D has stopped working, windows is looking for a solution" then it changes to I will be notified when a solution is found. I have tried both 64 and 32 bit installations and bot react the same way.
Doug Irwin
McKinney, Texas
Re: Simplify 3D won't start after installation
What does the crash report say? My first guess would be that it's an issue with your graphics driver
dougirwin212
All it says is that Simplify 3D has stopped working , then it says it is looking for a solution.
Error Message
Error Message
Simplify Error.PNG (25.08 KiB) Viewed 7149 times
First link on google for how to get a crash report in case you have never done it before: http://www.cyberlink.com/support/faq-co ... o?id=10449
dougirwin212
I reinstalled it this evening and after it failed I opened the Event Viewer:
Faulting application name: SIMPLI~1.EXE, version: 3.0.2.0, time stamp: 0x55d0f27f
Faulting module name: ig4icd64.dll, version: 8.15.10.1968, time stamp: 0x4ace019d
Exception code: 0xc0000005
Fault offset: 0x000000000003f9f8
Faulting process id: 0x9b4
Faulting application start time: 0x01d16abe33775c39
Faulting application path: C:\PROGRA~1\SIMPLI~1.2\SIMPLI~1.EXE
Faulting module path: C:\Windows\system32\ig4icd64.dll
Report Id: 8871a386-d6b1-11e5-8f1d-1078d27a602e
Yup, that's your graphics driver. You can tell by the log since it identifies exactly which program is causing the problem. So you can try updating your graphics driver, using a different driver (for people who have multiple cards in the same computer), uninstalling and reinstalling the driver, and some have even tried using the stock windows driver if the one they downloaded was too buggy to work.
There's a few threads on the forum you can easily search through that have similar advice
zylantha
I have the same issue on my laptop.
Faulting application name: Simplify3D.exe, version: 3.0.2.0, time stamp: 0x55d0f27f
Faulting module name: ig75icd64.dll, version: 10.18.14.4139, time stamp: 0x54e507b2
Fault offset: 0x000000000053abb5
Faulting process id: 0x6570
Faulting application start time: 0x01d16d3a5aa81b17
Faulting application path: C:\Program Files\Simplify3D-3.0.2\Simplify3D.exe
Faulting module path: C:\windows\system32\ig75icd64.dll
Report Id: a3298c7d-d92d-11e5-9fff-a0a8cd3281e6
Same thing. If you follow the details listed in that crash report, it also shows that the graphics driver is actually what's crashing and causing the problem. Try the suggestions I listed above.
zylantha
"Thank you" for your insights, however I believe you are far too quick to blame video drivers for the issue.
After a significant amount of effort to upgrade to alternate - and the very latest - drivers, same issue.
Faulting module name: ig75icd64.dll, version: 10.18.14.4332, time stamp: 0x564f8b48
Fault offset: 0x000000000054a985
Faulting process id: 0xbb4
Faulting application start time: 0x01d16ee150a14841
Report Id: 9b65965f-dad4-11e5-960b-a0a8cd3281e6
This is clearly an issue with Simplify3D as there are now three different graphics driver versions causing crashes of Simplify3D.
I'm also not impressed with SImplify3D's lack of response to my support request, given I've just spent a significant amount of money buying a license sight-unseen, and I still don't have it working on my laptop. It's not like my graphics adapter is particularly unusual or out of date (Intel 4400).
Well I'm just trying to help out, so you're welcome to investigate whatever you want. However, the crash report you posted clearly shows the problem is coming from the graphics driver. It's not a guess, it's exactly what is listed in the crash report.
So again, just trying to save you some time by pointing you in the right direction. Perhaps your graphics card just isn't compatible. You may also want to try uninstalling the graphics drivers completely and just using the stock Windows drivers to see if that does any better.
