Pumlux
One part with multiple processes and ooze shield ?
Hi all,
can anyone advice me on my topic ?
I want to print one part with two processes.
1. Process start at 0.00 mm and ends at 0.15 mm (because layer is 0.15 mm)
2. Process start at 0.15 and ends open
I want ot have different setting on the two processes e.g. Extrusion Multiplier, but I want an ooze shield going up to the top.
I can print without issues when not using a ooze shield, but when using an ooze shield the shield is only printed on layer one, the others have no ooze shield.
(The same when I use a skirt higher than 1 layer)
What is wrong here ?
Test mit Schrift.factory
Factory file from an example
(94.14 KiB) Downloaded 361 times
Re: One part with multiple processes and ooze shield ?
From what I can tell, the ooze shield and prime pillar can't be used if you are also using the "stop printing at height" option on the advanced tab. So you would have to use a single process if you wanted an ooze shield
Pumlux
That is a pitty.
How about having a skirt with a distance 1 - 2 mm from the print object ?
It looks like this is also stopping with the end of the first process.
Or is there a different way how I can have a higher extrusion multiplier defined for the first layer ?
davedelay
Pumlux wrote:That is a pitty.
It must be just the way it is. I'll check the forum for bugs and enhancements to see if "ooze shield" can be used on process starting at a height where the 1st process ends. :x
Chadd
Same issue here,
I sent a factory file to support so hopefully they will fix it, I would suggest you send an email with a factory file to support also.
rifraf650
Adding my $0.02 that it would be nice to be able to use an ooze shield, or prime pillar, on multiple processes. In my case, I want to do banded color parts with a dual extruder, but want to turn off the other extruder so there is less ooze. The problem is that I can not properly prime the nozzle at a tool change, and I get nasty globs. I've tried numerous script configurations using tool change and layer change scripts, but nothing gets it quite right.
sebastien
Same problem in France:
I want print one part with 2 process for win material:
- first process on 30mm bi material(support and model) with prime pillar
- second process from 30mm with just only model material and no prime pillar
The problem, on the first process the prime pillar don't integrate the support head!??
Why?
With one process for all i see the dual head on prime pillar, you can see it on the factory file!
Ps. the part on factory file is just an example for illustrated
multi-process.factory
(863.19 KiB) Downloaded 526 times
rifraf650
I added my solution to this issue here: viewtopic.php?f=8&t=6813
Really only addresses tool changes, but might be helpful.
