Is there any easy way to print the last three layers with a different process?
I need to give the last three layers a littlebit more temperature and more extrusion to get a better surface finish especially in the top layer.
I know I can use a second process for this but it is very complicated to find the right height in mm where the last three layers begin.
Is there any option to specify a process beginning from a certain layer instead from a height in mm?
Thanks...
