carlitototo
[SOLVED] No Support generated !
Hello,
First of all, sorry for my terrible Englisch, I'm French !
So, I have got simplify 3D since 2 days now and I tried to generate support material on a 3D model.... but it didn't work !
I followed the tutorial vidéo frome Simplify 3D ( https://www.youtube.com/watch?v=6tlrCpwAV4M ) but the software doesn't genarte support when clicking on the button =/
any idea of why it is like this ?
Thanks
Carlito
https://t.me/pump_upp
MasterFX
Re: No Support generated !
Maybe you used to high pillar resolution and/or wrong overhang angle. Or wrong Support Type (e.g. from Build Platform only)
Can you post the STL file where you have problems?
Or even better the Factory File (File => Save Factory File As)
carlitototo
The pillar resolution is at 4mm and I want the support to be frome the buildplate only !!!
Here is the factory file :
HELICE6.factory
(224.82 KiB) Downloaded 498 times
Thank you
Carlito
Jeff_Birt
I was trying to work with that file and it seems your STL has errors. Trying to fix them in S3D really messed things up. Perhaps others will have more luck.
MasterFX
Jeff_Birt wrote:I was trying to work with that file and it seems your STL has errors. Trying to fix them in S3D really messed things up. Perhaps others will have more luck.
Here we go. Works fine now. Used Freecad with this workflow: viewtopic.php?f=9&t=7381&p=31861#p31868
HELICE6_repaired.stl
(606.43 KiB) Downloaded 456 times
Repairing with Microsoft's free 3D Builder app also cured the problem. Its a free to download app in Windows10.
carlitototo
Hello,
I'm soooooooooo sooory I didn't answer before... I had my internet cut !!!! never take SFR as an internet provider in France !!!
I juste download the file and printed it... it seams it print well for now !
Thank you again !!!
Carlito
