jjudge8U
Angled supports
Need ability to have custom angle supports. Waste of print time and speed when you are printing 500 mm tall and you have to build a support all the way from the bed for something that could start 20 mm down at a 45 degree angle off the build.
rrdavis
Re: Angled supports
Can you post a photo of the print you are referring to showing the desired supports vs the ones that got added by default?
jab136
Re: Angled supports
I don't know if this exactly what the OP was talking about but here is an stl for a part that I tried to print a while back, the cone angles are 75 degrees so they need support, but that support doesn't need to come all the way from the previous cone.
75 degrees_4 columns redo.STL
(297.64 KiB) Downloaded 241 times
jwilbourne
Re: Angled supports
Please add Angled Supports
