hopper01_68
Received: OFFLINE_NO
Was wondering if anyone has seen this when printing through USB, using S3D,
I have a Da Vinci 2.0, when trying to print large prints I get this( picture attached ) RECEIVED: OFFLINE_NO on the send G-Code page.
I can send small prints just fine.
Re: Received: OFFLINE_NO
It means either something is wrong with the da vinci firmware or that the file upload failed. For example, I think you can get that if the SD card fills up or sometimes when you trigger a bug in the firmware. Try sending a smaller file. Does that work?
BaudR8
try the suggestion in this post:
viewtopic.php?p=11302#p11302
see if that works for you
hopper01_68
JoeJ wrote:It means either something is wrong with the da vinci firmware or that the file upload failed. For example, I think you can get that if the SD card fills up or sometimes when you trigger a bug in the firmware. Try sending a smaller file. Does that work?
Yes if I use the same file and only change the scale of the part to a smaller one, then it will go through. I have tried to step it down before and it finally went through.
BTW, I can use the stock xyzware and it sends a big file just fine, just don't have the adjustments that S3D has.
I have changed out my SD card from the stock 4 gig to a 32gig wireless card, just need to figure out how to work the wireless part, lol
I will try the baud rate on my next print.
