InspGadgt
Re: Simplify3D V5 no longer useable for RC airplane prints
Here is the stl for the part I've been using for testing.
Ste wing DOWN L 3.stl
(1.15 MiB) Downloaded 328 times
What is the sliced part supposed to look like? I did a check on the file and it has many errors and is 23 shells.
I've tried slicing in three slicers and get the same result in each.
Is there some specific settings they recommend?
I got it to slice in V4.1.2 but not in V5.
jfkansas
InspGadgt wrote: Thu Dec 15, 2022 4:14 pm
wirlybird wrote: Thu Dec 15, 2022 3:15 pm Yea! Got one thing fixed. I was looking at your model.
Here is something to try. Keep reducing the extrusion width, like 0.4 to 0.39 etc., and see if the parts show up at some point. this would indicate that the walls are very thin. Maybe it is a start.
I can try that but the models are designed for a specific line width of .42mm
Change minimum single extrusion width to 50% or lower.
Mayk
@ InspGadgt What Model is this? I have a lot 3dLabprint Models. Tried the B25 and it´s working, If you tell me what part makes the problems I can test it here.
Regards#
Mayk
jfkansas wrote: Fri Dec 16, 2022 2:42 am
I tried it at 1% and it still doesn't slice correctly.
InspGadgt
wirlybird wrote: Thu Dec 15, 2022 11:54 pm What is the sliced part supposed to look like? I did a check on the file and it has many errors and is 23 shells.
This is what it looks like sliced in PrusaSlicer.
InspGadgt
wirlybird wrote: Fri Dec 16, 2022 12:06 am I've tried slicing in three slicers and get the same result in each.
PrusaSlicer and Cura both can slice it properly with some settings adjustments.
https://3dlabprint.com/faq/prusaslicer/
https://3dlabprint.com/faq/cura/
Based on this thread, it sounds like it is still working correctly in V5:
viewtopic.php?t=16615
