INEEDHELP
Raft Height Ridiculous Ruining Everything
I use a Creality CR-10 with a .8mm nozzle.
When generating a RAFT, it starts at 2.2mm high up, printing in air for the first layer. if I reduce it to 1% for "first layer height" it still starts printing at 1.2mm high in the sky.
Due to this, I can't get the damn thing to stick at all.
How do I fix this?
There is no setting to adjust this so it just prints normally, at a normal layer height for the raft. I don't want to print 1mm in the sky, I want to print against the bed.
rrdavis
Re: Raft Height Ridiculous Ruining Everything
Sounds like you might need to check your Z-endstop or leveling probe
joesomething
Is the Z-offset set correctly? On my Prusa clone, I navigated to CONTROL>MOTION>Z OFFSET and continually adjusted the value, in conjunction with a 0.2mm feeler-gauge, until the extuder homed to the proper height for bed adhesion. Raising the value will move the nozzle downward. Be sure to store/save the value. I have to select BED LEVELING TEST to take the actual measurement prior to making an adjustment.
I've attached the leveling instructions that came with my printer, in case it helps.
P802 Automatic Leveling Debug Guide V2.pdf
(1.49 MiB) Downloaded 138 times
